Blackberry Tour 9630
If the LCD screen on your Blackberry Tour 9630 has cracked or is broken then this is the service for you. I come to you and fix it for a flat $50 – or you can come to my shop and have it fixed in front of you quickly. Most of the time, the repair takes less time than the Tour takes to boot up after a battery pull.
Your Blackberry is likely a tour if it is a Blackberry on Verizon or Sprint purchased in early 2009 with a trackball.
