This Macbook Pro retina logic board has no output on the internal screen. However, using a displayport to VGA adapter, I was able to get a picture to show upon an external monitor, and I was able to run ASD. ASD gave me an error, displayport symbol error. I investigated the displayport data lines and noticed one had no continuity due to a burned via inside the board.
This is one of those things where you will have people all over the internet telling you it is the lcd cable… but it’s never the LCD cable. It’s that good ol’ wishful thinking that there’s a brainless $4 solution to what is a much larger problem.
The solution here was to dig away until I got to the nub that the in-line capacitor in the displayport data line is soldered to. Since there was no pad left, I put solder and flux on a piece of wire, and did my best to tin the nub. I couldn’t use the soldering iron to solder it, even with the micro soldering iron’s smallest tip, so I put some flux there and used the hot air station to flow the little wire onto the nub. Then, I could solder the capacitor to the wire which was soldered to the nub and huzzah.. PICTURE!!!!
We regularly fix liquid spill damaged Macbook Pros with our Macbook liquid spill damage repair service. Watch how below!
I’ve learned newer and more effective things as a result of your site. One other thing I’d really like to say is that often newer computer system os’s are inclined to allow extra memory for use, but they likewise demand more memory simply to run. If one’s computer could not handle a lot more memory as well as newest software program requires that memory space increase, it may be the time to buy a new Computer. Thanks
Thanks for the marvelous posting! I quite enjoyed reading it, you might be a great author.I will ensure that I bookmark your blog and definitely will come back later in life. I want to encourage you to ultimately continue your great posts, have a nice holiday weekend!
I have checked your page and i have found some duplicate content,
that’s why you don’t rank high in google’s search results, but there is
a tool that can help you to create 100% unique content, search for: Boorfe’s tips unlimited content
